C cicciopippo n3wb Oct 14, 2020 5 0 italy Oct 14, 2020 #1 I have bricked my ipcam. i have already tried with tfpt, but it never shows "Device [192.0.0.64] system update completed!"
iTuneDVR Pulling my weight Aug 23, 2014 879 162 Россия Oct 18, 2020 #2 Open your ipc, find 4 pin ttl jack & connect it via ttl2usb adapter to your pc. Show log.
alastairstevenson Staff member Oct 28, 2014 16,233 7,008 Scotland Oct 18, 2020 #3 cicciopippo said: I have bricked my ipcam. Click to expand... What did you do to it? In what way is it bricked? Does it show in SADP?
C cicciopippo n3wb Oct 14, 2020 5 0 italy Oct 19, 2020 #4 iTuneDVR said: Open your ipc, find 4 pin ttl jack & connect it via ttl2usb adapter to your pc. Show log. Click to expand... hi, thanks for the reply. with which program I show you the log ?
iTuneDVR Pulling my weight Aug 23, 2014 879 162 Россия Oct 19, 2020 #5 PuTTY Setup save session to file before connection
