Hello.
Got a chinese version of the DS-2CD2732F-IS. I hooked it up to my switch in the garage. The camera powered on fine. I then opened up SADP, and found the unit and changed the ip address to 192.x.x.150. Everything looked great.
I then went into Synology Surveillance Station and set the camera up there. It worked great and I was able to see images from the camera.
Today, I mounted the camera on the porch. I plugged it in to the cat 5e and the IR lights came on as well as the little red light inside.
After it was hung up, i pulled out my phone to see what adjustments needed to be made to the viewing angle. The camera never showed up on my network (using FING - it did show up last night). I checked the synology SADP again, and nothing appears.
The red light inside the unit is on, but I get no other indications that it's working or connected to my network. Any ideas on what I need to do? Thanks!
