I think I'm going to make my own template out of wood or plexi - and - drill out the holes in the metal base plates for the wire to pass through.
Did Hikvision ever use or test that template and install that ring?
I had some reservations when I looked at it upon receiving the unit. Thought it was odd there were no holes for the wires. Risk of pinching the wire. How to push slack in ... as there's no excess space in that ring ... wouldn't be an issue if that ring was the thickness of the cat wire connector.
In practice. Oh what fun!
Because:
Three of the holes they ask you to drill don't need to be drilled. They're to receive the camera.
There's no depiction of the 6 mounting holes you actually use.
The ring/plate pretty much completely obscures the holes for the misc wire and cat bundle.
Making it so you need four arms at the top of a ladder, guess and pre-drill the real mounting holes overhead ( dealing with some hardwood, can't imagine masonry or stucco right now), then when you try to put it on ... do not drop the camera, hold on to the ring, feed the wire, grab screws ... screwdriver.
I thought the sticker template was neat, but it doesn't have the right information; and the bracket seems like for another camera with wires through the center.
Because:
