DS-2CD2532F Pinout or color of Ethernet wires required
Nitin
Jan 26, 2015
34
2
Hello
I did not secure the Ethernet port of DS-2532F and during rain - water seeped into it.
Seems there was spark, and my PoE switch shutdown the power(Its a Nortel switch). Unfortunately, the pins of the socket got consumed in the park.
The camera powers up(12V) but doesnot respond to Ethernet. I can see physical damage on pin 7,8.
Before I cut the cable and solder new Ethernet socket - I want to hear if anybody else had this situation and how they solved it.
Ofcourse - I would require help in identifying colors of the cable after I cut it.
Thank you
Nitin
Thanks for the link - Since I have only 2 pins which are damaged, I will figure out the black grey issue of Lorex vs Hikvision will be very easy to identify using multimeter.
attachment.php
attachment.php
Sorry for upload this topic... but
someone knows where can I get the original pigtail from Hikvision cameras?
Thanks in advanced
