Good afternoon! I have a DS-2CD2522FWF-IS model camera that doesn't want to boot. Help me figure out the log. Should I choose immediately or leave it?
U-Boot 3.1.6-269644 (Jul 6 2017-10:47:55)
boards:296717
Boot From: NAND 2048 RC
SYS_CONFIG: 0x30060059 POC: 100
Cortex freq: 600000000
ENET freq: 50000000
iDSP freq: 216000000
Dram freq: 564000000
Core freq: 216000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
dev_model
S-2CD2522FWD-IS
Hit Ctrl+u to stop autoboot: 0
|BIND err|
cmd 'null' is not supported.
nand booting ...
booting from pri part...
load kernel...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.10.73+ (zhangjianzhong@Cpl-Frt-BSP) (gcc ?? 4.8.2 20130902 (prerelease) (crosstool-NG - Ambarella Linaro Multilib GCC [CortexA9 & ARMv6k] 2013.09) ) #1 PREEMPT Wed May 25 11:41:54 CST 2016
[ 0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: Ambarella S2L (Flattened Device Tree), model: Ambarella S2LM Kiwi Board
[ 0.000000] dev type:0x2243
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] Ambarella: AHB = 0xe0000000[0xe0000000],0x01000000 0
[ 0.000000] Ambarella: APB = 0xe8000000[0xe8000000],0x01000000 0
[ 0.000000] Ambarella: PPM = 0x00000000[0xdfe00000],0x00200000 9
[ 0.000000] Ambarella: AXI = 0xf0000000[0xf0000000],0x00030000 0
[ 0.000000] Ambarella: DRAMC = 0xdffe0000[0xef000000],0x00020000 0
[ 0.000000] Ambarella: DBGBUS = 0xec000000[0xec000000],0x00200000 0
[ 0.000000] Ambarella: DBGFMEM = 0xee000000[0xee000000],0x01000000 0
[ 0.000000] Ambarella: IAVMEM = 0x06800000[ ],0x09800000
[ 0.000000] Ambarella: FBMEM = 0x06800000[ ],0x00000000
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 25908
[ 0.000000] Kernel command line: console=ttyS0 KRN_PRT=pri
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 102MB = 102MB total
[ 0.000000] Memory: 95308k/95308k available, 9140k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0x86800000 - 0xff000000 (1928 MB)
[ 0.000000] lowmem : 0x80000000 - 0x86600000 ( 102 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x804fe3e8 (5081 kB)
[ 0.000000] .init : 0x804ff000 - 0x80780a24 (2567 kB)
[ 0.000000] .data : 0x80782000 - 0x807ca110 ( 289 kB)
[ 0.000000] .bss : 0x807ca110 - 0x807edc68 ( 143 kB)
[ 0.000000] NR_IRQS:240
[ 0.000000] sched_clock: 32 bits at 54MHz, resolution 18ns, wraps every 79536ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [ttyS0] enabled
[ 0.237775] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[ 0.302602] pid_max: default: 32768 minimum: 301
[ 10.311633] Mount-cache hash table entries: 512
[ 10.318604] CPU: Testing write buffer coherency: ok
[ 10.323785] Setting up static identity map for 0x803c60b0 - 0x803c6118
[ 10.333859] devtmpfs: initialized
[ 10.338308] pinctrl core: initialized pinctrl subsystem
[ 10.343856] NET: Registered protocol family 16
[ 10.349013] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 10.356380] L310 cache controller enabled
[ 10.360414] l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x32020000, Cache size: 131072 B
[ 10.369815] ambarella-pinctrl e8009000.pinctrl: Ambarella pinctrl driver registered
[ 10.377822] ambarella-gpio gpio.0: Ambarella GPIO driver registered
[ 10.388091] bio: create slab <bio-0> at 0
[ 10.393204] ambarella-dma e0005000.dma: Ambarella DMA Engine
[ 10.400873] ambarella-i2c e8003000.i2c: Ambarella I2C adapter[0] probed!
[ 10.407850] Advanced Linux Sound Architecture Driver Initialized.
[ 10.414657] Switching to clocksource ambarella-cs-timer
[ 10.426402] ambarella-sd e0002000.sdmmc0: Slot0 use bounce buffer[0x85f20000<->0x06120000]
[ 10.434693] ambarella-sd e0002000.sdmmc0: Slot0 req_size=0x00020000, segs=32, seg_size=0x00020000
[ 10.443566] ambarella-sd e0002000.sdmmc0: Slot0 use ADMA
[ 10.519953] ambarella-sd e0002000.sdmmc0: 1 slots @ 50000000Hz
[ 10.525932] NET: Registered protocol family 2
[ 10.531182] TCP established hash table entries: 1024 (order: 1, 8192 bytes)
[ 10.538149] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 10.545621] TCP: Hash tables configured (established 1024 bind 1024)
[ 10.552042] TCP: reno registered
[ 10.555260] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 10.561107] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 10.567531] NET: Registered protocol family 1
[ 10.572187] RPC: Registered named UNIX socket transport module.
[ 10.578088] RPC: Registered udp transport module.
[ 10.582830] RPC: Registered tcp transport module.
[ 10.587513] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 10.784232] msgmni has been set to 186
[ 10.789256] NET: Registered protocol family 38
[ 10.793869] io scheduler noop registered
[ 10.797775] io scheduler deadline registered
[ 10.802082] io scheduler cfq registered (default)
[ 10.807601] e8005000.uart: ttyS0 at MMIO 0xe8005000 (irq = 9) is a ambuart
[ 10.815382] brd: module loaded
[ 10.821123] loop: module loaded
[ 10.826973] ambarella-nand e0001000.nand: in ecc-[1]bit mode
[ 10.832664] ambarella_nand: Use On Flash BBT
[ 10.836986] NAND device: Manufacturer ID: 0x98, Chip ID: 0xf1 (Toshiba NAND 128MiB 3,3V 8-bit), 128MiB, page size: 2048, OOB size: 64
[ 10.849221] Bad block table found at page 65472, version 0x01
[ 10.855152] Bad block table found at page 65408, version 0x01
[ 10.861073] nand_read_bbt: bad block at 0x000001ae0000
[ 10.866201] nand_read_bbt: bad block at 0x000006000000
[ 10.871424] 16 ofpart partitions found on MTD device amba_nand
[ 10.877233] Creating 16 MTD partitions on "amba_nand":
[ 10.882401] 0x000000000000-0x000000020000 : "bst"
[ 10.887859] 0x000000020000-0x000000120000 : "bld"
[ 10.893265] 0x000000120000-0x000000200000 : "ptb"
[ 10.898559] 0x000000200000-0x000000280000 : "env"
[ 10.903943] 0x000000280000-0x000000380000 : "sysflg"
[ 10.909560] 0x000000380000-0x000000400000 : "param"
[ 10.915151] 0x000000400000-0x000000500000 : "dpt"
[ 10.920567] 0x000000500000-0x000000f00000 : "rcvy"
[ 10.926018] 0x000000f00000-0x000001700000 : "krn_pri"
[ 10.931791] 0x000001700000-0x000001f00000 : "krn_sec"
[ 10.937518] 0x000001f00000-0x000004100000 : "app_pri"
[ 10.943347] 0x000004100000-0x000006300000 : "app_sec"
[ 10.949068] 0x000006300000-0x000006900000 : "cfg_pri"
[ 10.954811] 0x000006900000-0x000006f00000 : "cfg_sec"
[ 10.960547] 0x000006f00000-0x000007700000 : "dbg"
[ 10.965891] 0x000007700000-0x000007f00000 : "syslog"
[ 10.972049] ambarella-spi e0020000.spi: SPI[0] uses DMA
[ 10.977409] ambarella-spi e0020000.spi: Ambarella spi controller 0 created.
[ 10.984615] tun: Universal TUN/TAP device driver, 1.6
[ 10.989645] tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
[ 11.049895] libphy: Ambarella MII Bus: probed
[ 11.054249] mdio_bus e000e000.etherne: /ahb@e0000000/ethernet@e000e000/phy@0 has invalid PHY address
[ 11.063381] mdio_bus e000e000.etherne: scan phy phy at address 0
[ 11.070880] mdio_bus e000e000.etherne: registered phy phy at address 0
[ 11.077401] ambarella-eth e000e000.ethernet: Ethernet PHY[0]: 0x001cc816!
[ 11.084709] ambarella-eth e000e000.ethernet: MAC Address[4c:bd:8f:d8:34:ef].
[ 11.091854] PPP generic driver version 2.4.2
[ 11.096302] PPP BSD Compression module registered
[ 11.101025] PPP Deflate Compression module registered
[ 11.106234] mousedev: PS/2 mouse device common for all mice
[ 14.109906] ambarella-i2c e8003000.i2c: No ACK from address 0xa2, 0:0!
[ 14.116771] ambarella-rtc e8015000.rtc: rtc core: registered rtc-ambarella as rtc0
[ 14.124457] pcf85163 is not exist.
[ 14.127840] i2c /dev entries driver
[ 14.132028] ambarella-wdt e800c000.wdt: Ambarella Watchdog Timer Probed.
[ 14.139361] Netfilter messages via NETLINK v0.30.
[ 14.144183] nf_conntrack version 0.5.0 (1489 buckets, 5956 max)
[ 14.150475] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 14.155812] TCP: cubic registered
[ 14.159140] NET: Registered protocol family 10
[ 14.164476] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 14.169948] sit: IPv6 over IPv4 tunneling driver
[ 14.175152] NET: Registered protocol family 17
[ 14.179638] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 14.187316] ThumbEE CPU extension supported.
[ 14.192766] ambarella-rtc e8015000.rtc: setting system clock to 1970-01-04 18:02:34 UTC (324154)
[ 14.201648] ALSA device list:
[ 14.204601] No soundcards found.
[ 14.210659] Freeing unused kernel memory: 2564K (804ff000 - 80780000)
init started: BusyBox v1.19.3 (2016-05-25 11:39:54 CST)
starting pid 45, tty '': '/etc/init.d/rcS'
Starting udev: [ OK ]
[ 14.807931] UBI: attaching mtd10 to ubi1
[ 14.902348] UBI: scanning is finished
[ 14.916667] UBI: attached mtd10 (name "app_pri", size 34 MiB) to ubi1
[ 14.925842] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 14.932692] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 14.939370] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 14.946245] UBI: good PEBs: 272, bad PEBs: 0, corrupted PEBs: 0
[ 14.952155] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 14.959264] UBI: max/mean erase counter: 4111/3314, WL threshold: 4096, image sequence number: 1634028664
[ 14.968813] UBI: available PEBs: 0, total reserved PEBs: 272, PEBs reserved for bad PEB handling: 10
[ 14.977944] UBI: background thread "ubi_bgt1d" started, PID 270
UBI device number 1, total 272 LEBs (34537472 bytes, 32.9 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi1_0.
[ 14.999477] UBIFS: background thread "ubifs_bgt1_0" started, PID 275
[ 15.026853] UBIFS: recovery needed
[ 15.092596] UBIFS: recovery completed
[ 15.096450] UBIFS: mounted UBI device 1, volume 0, name "app_pri"
[ 15.102604] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 15.111735] UBIFS: FS size: 31490048 bytes (30 MiB, 248 LEBs), journal size 1523712 bytes (1 MiB, 12 LEBs)
[ 15.121372] UBIFS: reserved for root: 1487352 bytes (1452 KiB)
[ 15.127189] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 21554B09-04AC-45CD-BFCE-9CDA8188DB76, small LPT model
pri_iUpgSuccCnt:1, sec_iUpgSuccCnt:1
[ 15.150612] UBI: attaching mtd12 to ubi3
[ 15.170534] UBI: scanning is finished
[ 15.184348] UBI: attached mtd12 (name "cfg_pri", size 6 MiB) to ubi3
[ 15.193413] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 15.200265] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 15.206942] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 15.213814] UBI: good PEBs: 48, bad PEBs: 0, corrupted PEBs: 0
[ 15.219622] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 15.226749] UBI: max/mean erase counter: 33561/31531, WL threshold: 4096, image sequence number: 923331527
[ 15.236385] UBI: available PEBs: 0, total reserved PEBs: 48, PEBs reserved for bad PEB handling: 10
[ 15.245429] UBI: background thread "ubi_bgt3d" started, PID 279
UBI device number 3, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi3_0.
[ 15.266869] UBIFS: background thread "ubifs_bgt3_0" started, PID 284
[ 15.294291] UBIFS: recovery needed
[ 15.312382] UBIFS: recovery completed
[ 15.316239] UBIFS: mounted UBI device 3, volume 0, name "cfg_pri"
[ 15.322410] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 15.331621] UBIFS: FS size: 3047424 bytes (2 MiB, 24 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 15.340974] UBIFS: reserved for root: 143937 bytes (140 KiB)
[ 15.346638] UBIFS: media format: w4/r0 (latest is w4/r0), UUID AA7EE588-3739-4249-B54A-855A6889835E, small LPT model
Check dir /davinci ok! (0)
[ 15.401936] UBI: scrubbed PEB 45 (LEB 0:10), data moved to PEB 41
[ 15.413102] UBI: attaching mtd13 to ubi4
[ 15.433836] UBI: scanning is finished
[ 15.447830] UBI: attached mtd13 (name "cfg_sec", size 6 MiB) to ubi4
[ 15.456892] UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 15.463738] UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 15.470435] UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 15.477283] UBI: good PEBs: 48, bad PEBs: 0, corrupted PEBs: 0
[ 15.483105] UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 15.490225] UBI: max/mean erase counter: 16044/13364, WL threshold: 4096, image sequence number: 262606683
[ 15.499846] UBI: available PEBs: 0, total reserved PEBs: 48, PEBs reserved for bad PEB handling: 10
[ 15.508887] UBI: background thread "ubi_bgt4d" started, PID 289
UBI device number 4, total 48 LEBs (6094848 bytes, 5.8 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
waiting for /dev/ubi4_0.
[ 15.541484] UBIFS: background thread "ubifs_bgt4_0" started, PID 294
[ 15.569920] UBIFS: recovery needed
[ 15.588754] UBIFS: recovery completed
[ 15.592648] UBIFS: mounted UBI device 4, volume 0, name "cfg_sec"
[ 15.598766] UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 15.607901] UBIFS: FS size: 3047424 bytes (2 MiB, 24 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 15.617192] UBIFS: reserved for root: 143937 bytes (140 KiB)
[ 15.622847] UBIFS: media format: w4/r0 (latest is w4/r0), UUID 4E312AE9-B29F-461B-B0EA-3AED396AF98A, small LPT model
Check dir /config ok! (0)
diagnose_way = 15, repair_way = 1, interval = 60
[ 15.687337] net eth0: adv: sym 1, asym: 1
[ 15.691600] net eth0: lp: sym: 0, asym: 0
[ 15.695664] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
route: ioctl 0x890c failed: No such process
cp: can't stat 'half_secinfo.dat': No such file or directory
[ 17.680907] net eth0: lp: sym: 1, asym: 0
[ 17.684910] libphy: e000e000.etherne:00 - Link is Up - 100/Full
[ 17.697301] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 17.711840] dsp: module license 'Proprietary' taints kernel.
[ 17.717488] Disabling lock debugging due to kernel taint
Default method to init without VIN drivers...
Cat this file to find out what VIN can be supported.
Default init without lens driver
[ 17.863733] amba_debug_init 248:248.
Use default settings
/home/script/init.sh: line 378: which: not found
/home/script/init.sh: line 389: /lib/firmware: Permission denied
Load ucode failed!
[ 17.967853] base module init.
[ 17.979870] <0>=====>flag1=0x0, flag2=0x0, flag3=0x0
[ 17.991511] read 'parms' failed!
[ 17.994733] get hardware info failure!
[ 17.998460] [ kernel version: svn-195302 ]
[ 18.002758] mmc0 power register success!
[ 18.006701] mmc1 power register success!
[ 18.010636] request sd[mmc1] power ctrl pin error!
[ 18.015406] usb0 power register success!
[ 18.035233] usbcore: registered new interface driver usbfs
[ 18.048602] usbcore: registered new interface driver hub
[ 18.057407] usbcore: registered new device driver usb
[ 18.068104] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 18.078811] ehci-ambarella: AMBARELLA-EHCI Host Controller driver
[ 18.087270] ambarella-ehci e0018000.ehci: EHCI Host Controller
[ 18.093265] ambarella-ehci e0018000.ehci: new USB bus registered, assigned bus number 1
[ 18.101484] ambarella-ehci e0018000.ehci: irq 39, io mem 0xe0018000
[ 18.119932] ambarella-ehci e0018000.ehci: USB 2.0 started, EHCI 1.00
[ 18.126358] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 18.133470] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 18.140702] usb usb1: Product: EHCI Host Controller
[ 18.145561] usb usb1: Manufacturer: Linux 3.10.73+ ehci_hcd
[ 18.151127] usb usb1: SerialNumber: AmbUSB
[ 18.157891] hub 1-0:1.0: USB hub found
[ 18.166918] hub 1-0:1.0: 2 ports detected
map_size = 0x400000, nr_item = 3
addr_offset = 0x00000000, filename = orccode.bin
addr_offset = 0x00300000, filename = orcme.bin
addr_offset = 0x003a0000, filename = default_binary.bin
mmap returns 0x76a82000
loading /home/firmware/orccode.bin...addr = 0x76a82000, size = 0x16e58d
loading /home/firmware/orcme.bin...addr = 0x76d82000, size = 0x4fb90
loading /home/firmware/default_binary.bin...addr = 0x76e22000, size = 0x40000
u_code version = 2016/5/17 256527.256579
ln: prtLensCurve: File exists
ln: /dev/ttyS1: File exists
ln: /bin/t1: File exists
cp: can't stat '/dav/libutils.so': No such file or directory
chmod: /lib/libutils.so: No such file or directory
ln: /dev/rtc: File exists
=====check_config start=====
===db file doesn't exist===
==== both config files are broken====
infd read End
Unix bus 0 .
Enter DB_main-------------------
shared memory address is: 0x76c61000, sizeof(DEVICECONFIG) = 887600
netprocess Infomation:
version: 1.7.1.179932 [14:15:42-Mar 23 2016].
Path: /Camera/Platform/Trunk/FSP_network_protocol
Last Changed Rev: 181496
Last Changed Date: 2016-03-09 09:53:14 +0800 (Wed, 09 Mar 2016)
wait davinci set default...
copy default.cls ok.
[01-04 18:02:44][pid:516][IPC][ERROR]daemon can not find Dst process.load_type 0x10027 is_need_ack 1
[01-04 18:02:44][pid:0][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10027]
get davinci_init_finished err.
In pppoe sleep
[01-04 18:02:45][pid:516][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-04 18:02:45][pid:524][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[01-04 18:02:45][pid:524][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-04 18:02:45][pid:524][UNI_IF][ERROR]communicaite_to_davinci failed!!!
IEfile uncompressed.
[01-04 18:02:46][pid:516][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-04 18:02:46][pid:524][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[01-04 18:02:46][pid:524][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-04 18:02:46][pid:524][UNI_IF][ERROR]communicaite_to_davinci failed!!!
Unix bus End
[ 26.646359] <0>=====>flag1=0x0, flag2=0x0, flag3=0x0
[ 26.651367] read 'parms' failed!
[01-04 18:02:46][pid:545][HW_IF][ERROR]ioctl error errno=5
[01-04 18:02:46][pid:545][SYSINIT][ERROR]hwif_getsecinfo failed.
[01-04 18:02:46][pid:545][SYSINIT][ERROR]sys app init failed to reboot!
[01-04 18:02:47][pid:516][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-04 18:02:47][pid:524][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[01-04 18:02:47][pid:524][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-04 18:02:47][pid:524][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[01-04 18:02:47][pid:516][IPC][ERROR]daemon can not find Dst process.load_type 0x10027 is_need_ack 1
[01-04 18:02:47][pid:0][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10027]
In pppoe sleep
[01-04 18:02:48][pid:516][IPC][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[01-04 18:02:48][pid:524][IPC][ERROR] from daemon ack, dst not work len 0 , load_type is [0x10012]
[01-04 18:02:48][pid:524][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[01-04 18:02:48][pid:524][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[ 28.655766] ambarella-wdt e800c000.wdt: ambarella_wdt_shutdown @ 4.
[ 28.662073] Restarting system.
[\spoiler]
boards:296717
ENET freq: 50000000
AHB freq: 108000000
APB freq: 54000000
UART freq: 24000000
SD freq: 50000000
SDIO freq: 50000000
SDXC freq: 60000000
dev_model
|BIND err|
nand booting ...
load kernel...
Load ucode failed!
infd read End
Unix bus 0 .
In pppoe sleep
Unix bus End
In pppoe sleep
[\spoiler]
