I have two DS-2CD2442FWD-IW which connect no problem via POE but not on 12v dc power.
The camera is able to connect to the WIFI network while on POE, and am able to access the cam via the Wireless IP address assigned but only while connected via the POE. It also registers two IPs one for Lan and one for Wlan in the router. Both are connected.
Once I connect with the 12v dc adapter, it is not discovered, all camera lights are on, IR switches on and off depending on the lights and am able to ping the camera on its wifi address.
The address tries to resolve but gets a connection time out and resolves to the below address as it tries to log in.
http://192.168.1.217/doc/page/login.asp?_1488096859292
No graphics are displayed though.
Also while on DC power it is not discovered in the router.
One thing I noticed is while its connected via POE, the default gateway in SADP for the WIFI IP always resets back to 0.0.0.0, even though inside it has the correct default gateway. LAns default is correct in SADP.
Not sure if its a power, settings, FW or hardware issue.
Your thoughts are appreciated.
