re: Motion Detection outside "AREA(s)" I drew.
_ DS-2CD2432F-IW { F/W Vers V5.3.0 build 150423 }
HI,
How can I stop the recording of motion outside the "area(s)" I defined?
I use two of these cams, both are detecting/recording on motion outside of the zone(s) drawn/selected on the
Advanced Configuration-MotionDetection webpage.
I have used both Expert & Normal and have Enabled/Disable that Dynamic Analysis; & of-course repeated Reboots.
On the image below you can observe
thanks for assist.. O.T.
p.s. sorry if this has been answered before ... search was not productive
HI,
the (2)SmartEvents(blue) and
the Red-Box/Zones which I define, but also
the "Green Boxes" where the camera detects motion;
that's fine, but I don't need it "recording"
