- Aug 30, 2014
- 340
- 153
Camera: DS-2CD2432F-IW
Firmware: 5.2.5 build 141201 (Original firmware in back label: 5.2.8 build 141231)
NVR: DS-7608N-E2/8P
Firmware: 3.3.2 build 150522
Anyone with luck getting this camera's internal PIR to work with Hikvision NVR? None of the different firmwares I've used with my DS-7608N-E2/8P NVR seems to be able to trigger the NVR to record or activate the Event settings for higher FPS/Bitrate. I know the PIR is working, because I'm able to configure/trigger it directly in the camera's web interface and hear the audible alarm. Also, I was able to get the camera in BlueIris to record clips whenever it detects motion using the following guide (link). With the latest firmware I have installed (3.3.2) it doesn't even shows as an option, so I'm wondering if it is not possible at all, or if it is due to a configuration issue and/or firmware for the camera and/or NVR. Thanks again for any help.
NVR: DS-7608N-E2/8P
