Hi to all,
I have upgraded a couple of Hikvision DS-2CD2432F-IW camera to latest Firmware 5.4 (Baseline Firmware_IPC_R0 series_En_v5.4.0 160530).
After the upgrade the camera are working fine but there is a problem.
I'm using the continuos mode recording on a 64 GB SD Card and in the Storage Schedule Settings I disabled the checkbox "Overwrite" (see atthached picture). This is very important for my needs that the recordings are never deleted when the SD card is Full.
The problem is that the camera always overwrite the recordings on SD Card even with Overwrite Disabled.
With the 5.3 firmware this setting are working good.
Someone can help me with this bug?
There is a hack to downgrade the firmware to 5.3?
Thank you.
Thank you.
