Hi all, I have 5 DS-2CD2387G2-LU cams and all working fine with a DS-7616NI-I2. However, I have a few questions if anyone can help me.
I am running the latest firmware on the cams V5.7.14 build 231028
I am looking for a bit of advice on events, basic vs smart if anyone can help.
1 - I have basic events set up and have it configured to record on motion, all working fine. However, all the videos I see allow you to draw the area using a multipoint green box. My cams all only offer the more basic and less accurate red box grid. Am I doing something wrong. I thought all the G2 devices allowed the creation of your monitoring area using the multipoint green user defined shape/area?
2- I only use basic events at the moment. Do I only use smart events if i want to do vehicle detection, face detection, line crossing etc? And if I wanted to do that, do i have both basic and smart enabled at the same time or is that a bit silly as I believe the smart events are to cut down on false positives?
3 - VCA resource. Its current set to monitoring, what does that give me exactly. I know I need to toggle onto the face or vehicle if I want to use that but if I dont, what do I get with Monitoring VCA resource
4 - And lastly, my sister has a similar setup. I installed that myself too. However she has monitors connected directly to the NVR whereas I connect to the NVR with a browser from my main PC. When I look at her playback, it allows you just to play back through motion events and it skips through by itself. Only difference is she is recording 24x7 and I only record on motion and of course I am accessing via browser. Is there a way I can get the playback just to skip through any motion without me having to adjust where I am on the timeline etc. Her setup is far more convenient for playback.
Sorry if they are silly questions, any help or advice really appreciated.
thanks all, super helpful forum here.
Darren.
Darren.
