DS-2CD2347G1-LU - Firmware update
Amir.Idris
Mar 23, 2022
40
8
Birmingham
HI All
After the latest firmware for Hikvision camera model DS-2CD2347G1-LU (I have 5 of them in total)
I know the Hikvision portal and have downloaded firmware for my NVR but not sure which firmware I need for my cameras as there is so much on there and its really confusing.
Any help or point in the right direction will be greatly appreciated :)
HI All
sorry I mean which platform do they fall under ?
Hi @Amir.Idris
G1 Platform
I think the firmware you are looking for is here:
HIKVISION UK PORTAL (hikvisioneurope.com)
What version of the firmware are the cameras running now? Do you see that version in the list at the link above?
Of course, it's a good idea to read the release notes for each of the firmware, and definitely notice the note under version V5.6.4 build 191224:
"Note: Please do not downgrade the device with factory version 5.6.4 to below 5.6.4.txt"
You can also search for the latest firmware using a camera's serial number using the following link... but only if the camera was affected by the recent Command Injection Vulnerability.... some of the G1 cameras were affected and some were not... the page will tell you when you try a serial number there.
Firmware Download | Security Notification - Command Injection Vulnerability in Some Hikvision products | Hikvision
Reactions: Amir.Idris
Thanks John.
Useful to know you can search function using serial number, question.....when searching via serial number only 9 characters are allowed, which 9 characters do I use from the screenshot attached ? I have tried the first 9 characters after the camera model name and the last 9 characters too, nothing found, not sure if I am doing this correct. My screenshot also shows current firmware version of cameras.
My other issue is I cannot flip, rotate, extend, make smaller the line for line crossing detection. I have tried via web gui and IVMS200 and it does not allow, was able to do this before. My NVR is on the latest firmware which I did recently.
Then your camera serial number is: E52726034
I just tried and your camera is not affected by CIV so you will get:
"No firmware available. Only products affected by the vulnerability can be searched on the page."
While I was there I found the link that shows which cameras were affected:
Security Notification - Command Injection Vulnerability in Some Hikvision products | Command Injection Vulnerability | Hikvision
Your G1 model is not included in the list so all good.
Just tried on one of mine...In the camera web GUI you should be able to click/select the line... then each line "end" with have a small box that can be moved around?
Maybe different with different cameras/firmware so if that doesn't work, maybe try clearing the existing line and draw it again?
Thanks, all cameras firmware now updated to latest firmware
Its weird cause I used to have the same and could move this line, I thought updating the firmware might fix this but no its still the same. Rebooted NVR and each camera individually too, still no luck. I am at a loss with this one
