DS-2CD2345G0P-I from Real HD Store on Amazon
ekbrewer
Feb 19, 2016
67
24
Anyone know if it is safe to buy DS-2CD2345G0P-I from Real HD Store on Amazon. Need wide angle and want to stick with Hikvision, but seem to remember hearing about Amazon 3rd party sellers providing cameras with problematic firmwares.
Thanks!
Eric
Thanks!
Eric
The info on the vendor says they're based in Chicago. Since amazon says it has "free returns", I'd go for it.
Just don't expect the best low light performance from a 4MP cam with only a 1/2.7" sensor.
Reactions: ekbrewer
I sent them a msg andvthey saifd this:
Thank you for reaching out to us. Unfortunately this camera is not US version. It is international version with International English Firmware. Thanks
If you update it and it goes Chinese or bricks it is bad software LOL.
Basically if you set the camera up and like it, don't update it and you will be fine.
Reactions: ekbrewer
that’s what i was hoping. Just ordered. Any tips on what to look for with bad firmware when I get it?
If you dont need the large vertical FOV then this is a much better option. Its 199 now direct from Annke and is made by hikvision and will even take hik firmware. Much better low light and double the resolution plus you will get audio - both mic and speaker.
Nice looking camera. Thanks for the suggestion, but I do need that vertical FOV and also need IR.
Thanks!
Eric
What ended up happening with these? Were they good?
Yes, same exact model number. That was a few years ago and I don’t know if there are any more in stock anywhere
