You can find out the password yourself by using the form on the website.Hi, Any chance I can please get the password for this config? Thank you so much
..I hope this doesn't count as necroposting, but I'm trying to resurrect a DS-2CD2342WD-IYes, I can
The decrypted and decoded file reveals that there is the usual admin account, and an additional user account.
For account admin the password=admin2019
For account betreiber the password=betreiber2019
It looks like there is a third account
For account telefon the password=telefon2019
Good luck!
Certainly not - this is one of those on-going threads ...I hope this doesn't count as necroposting
That file - presumably from using the 'forgot password' button in SADP - is a reset request file that has to have a response from a Hikvision support system, it doesn't hold a password.I'll try and the XML file
That should work, it's a version which has the backdoor security vulnerability which allows a configuration file to be extracted without authentication.Camera firmware is V5.3.3, which is within the applicable firmwares
What did the browser show after the URL was applied in the address bar?Used above URL by substituting all camera IP's one by one, but again, nothing happens.
What am I doing wrong ?
aarggghhh, thanks mate. I am not very cluey with networkingDid you set the PC IP address to be in the same range as that of the NVR-connected cameras, such as 192.168.254.100 ?
The file, configurationFile, must be pre-unpacked.
