DS-2CD2332-I Firmware 4.0.9 with "CCRR" in serial number. Recommended firmware?
mandalay
Jul 16, 2015
12
1
I have an old DS-2CD2332-I that comes with 4.0.9 firmware and has "CCRR" in the serial number. The camera is dated some time in 2013. I would like to upgrade to a newer firmware version like 5.1.6 or 5.2.5. I wonder if I can upgrade it via the web UI or I should use TFTP. And is this a Chinese version even though it has CCRR instead of CCCH in the serial number?
Thanks for any help.
Use my posted 5.1.6 firmware and all will be good.
@whoslooking, you really need a signature with links. Not even I know where your posted 5.1.6 firmware is.
Good call, Just looked myself and couldn't find it in the forum too, must have posted it a good few times,
I've added the most called for Fw's to my Signature makes them easier to find now lol.
I'd recommend also mentioning those are all for Chinese region cams. If that is in fact what they are for.
I was able to upgrade it to 5.1.6 via TFTP. Thanks a bunch. Btw, the serial number is now CCWR, which is great. Does it mean I can update it using any firmware from Hikvision USA web site?
Thanks a bunch for your help, @whoslooking.:)
Yes your 100% World Region so you only need to use the US or EU firmwares.
Enjoy
