Hi!
i have made some earlier post of some streaming problem, its like this, i have 3 pcs of DS-2CD2132F-IS.
i have the exact same settings on all the cameras and they are all connected to a cat6 cable trough a gigabit switch, and why can i only get 1 of the cameras to stream smooth and nice,no stutters att all, and the other 2 are stuttering and freezing not giving me a smooth and nice image, i have looked at the settings several hours but i cant really figure it out, i have copied all the setting from the non stutter camera to the other 2, but it really doesnt matter.
The only thing i can think of is that they dont use the same firmware, the one that is working good use:
[TABLE="class: deviceinfotable"]
[TR]
[TD="class: rowheader deviceinfotd"]Firmware version[/TD]
[TD="class: deviceinfotd"]V5.2.0 build 140721[/TD]
[/TR]
[TR]
[TD="class: rowheader deviceinfotd"]Encoding version[/TD]
[TD="class: deviceinfotd"]V5.0 build 140714[/TD]
[/TR]
[/TABLE]
and the other 2 use: [TABLE="class: deviceinfotable"]
[TR]
[TD="class: deviceinfotd"]V5.2.5 build 141201[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[/TABLE]
could it be the firmware, and if so, can i change the firmware to the older one?
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TD]
[/TR]
[/TABLE]
