S Sylv_01 n3wb Sep 10, 2015 10 0 Dec 2, 2015 #1 Hello, I'm using DS-2CD2132 cams, with internal SD card for videos & pictures records. How can I backup the SD Card into a PC, by using Telnet or SSH or ftp tools like Filezilla ? Thanks in advance...
alastairstevenson Staff member Oct 28, 2014 16,236 7,009 Scotland Dec 2, 2015 #2 If you have the full shell access via telnet (not psh) then this should work for you, or provide some ideas: https://www.ipcamtalk.com/showthrea...32-SD-Card-files?p=40072&viewfull=1#post40072 Reactions: Sylv_01
S Sylv_01 n3wb Sep 10, 2015 10 0 Dec 3, 2015 #3 Thanks for your replies ! I can have access to my cams by telnet, so it should work fine ! I will try tomorrow, and post the result...
