If you are into IoT, Zwave long range will be flooding the market with new sensors soon. The new long range is supposed to have a mile of range on one single hop, and battery powered sensors are supposed to have up to a 10 year battery life. Not sure how soon you need to set something up, but it's coming soon. They will likely have wired contact sensors that you can connect to the driveway alarm of your choice, and it will transmit back to your hub, where you can then do whatever you want with the alert.
I use my regular zwave setup connected to my mighty mule driveway alert to get push notifications to our phones whenever someone pulls into my driveway, which is about 375-400 ft long.
Z-Wave Long Range unlocks new possibilities for IoT automation
Z-Wave Long Range extends the range and maximum output power of the Z-Wave network protocol, supporting up to 4,000 nodes on a single network.www.electronicproducts.com
These work great every time! If you need to extend wire make sure you use shielded cable. I have installed probably 30 if these in the past 10 years and have never had any issues at all. They work as Mier DA500 Drive-Alert Wired Vehicle Driveway Alarm should.Anyone have any luck with a long range driveway alarm? I have tired one or two but they never work very well.....no alarm at all or false alarms. I bought cheap models $40. I wonder if the more costly models would be any better.
1200 feet for most wireless alarm devices is way too far; considering the FSPL and output power of most devices in the ~300-400Mhz range, you have a few options.Anyone have any luck with a long range driveway alarm? I have tired one or two but they never work very well.....no alarm at all or false alarms. I bought cheap models $40. I wonder if the more costly models would be any better.
Do you have any existing automation system? I accomplish this with homeseer and a mimolite at my house.I ended up with a Dakota alert 4k plus it seems to work great!
Now that next part how can i get alerts on my phone when someone enters the driveway?
The Receiver that sits in your house has two NO/NC relays and a 12VDC terminal to trigger external devices.
Is there a wifi module that can do this?
I know you guys are crafty!
You can also tie it into an alarm system like a dsc powerseries if you use an envisalink for self monitoring.
If you have any existing equipment let us know as it's best to tie into that if possible.
Could use old android phone and free automation app (there are several I recall). NO/NC wired to Android earplug was trigger.I ended up with a Dakota alert 4k plus it seems to work great!
Interesting! I did the same thing with two M Mule sensors at the end of a few hundred feet of wire. I lost one of them to lightning and replaced it with a Cartell, just because the interface is simpler. I bought a 2nd Cartell assuming the other M Mule would die, and the spare has been sitting on the shelf for a couple of years now.found a way to use the M Mule xmitter flashing leds to trigger a relay which triggers camera alarm input so went that route instead.
GTK about carter if I ever need one in future.Interesting! I did the same thing with two M Mule sensors at the end of a few hundred feet of wire. I lost one of them to lightning and replaced it with a Cartell, just because the interface is simpler. I bought a 2nd Cartell assuming the other M Mule would die, and the spare has been sitting on the shelf for a couple of years now.
