Hi-
I installed a security camera above our garage after drilling through the exterior wall. Everything was easy and went great.
I don't have a power source for where I want to add another camera so I just ordered a PEO injector (will see if that even works today with my Defender 2K Camera). I would like to install our camera on the outside corner of the room in this picture at the the top of the window approximately. This is the lower level our our home and as far as I know there shouldn't be any plumbing or much of anything other than the outlet in the picture.
I am a bit afraid to drill through anything but I just want to get this done. If you have to drill through this wall where would you recommend aiming for or where would you recommend staying away from? I think the closer I am to the outlet the better because that is where I will have the POE injector plugged in, but really dont want to hit a wire or anything. There is another outlet 5 feet or so to the right and same for the left. So I am assuming the wires are run horizontally at the level of the outlets? Any tips o recommendations would be appreciated.
Thanks!
Thanks!
