2025_10_18 UPDATE: This problem still exists with the new T54PRO-ZE ... using both @EMPIRETECANDY and Dahua firmware.
It's very easy to demonstrate. Login to the camera web interface with any of Chrome, Edge, Firefox in Windoze. First, pretty much everything works ... WITHOUT the plug-in ... good work Dahua. Click the Snapshot button and you'll see the ~10 MBYTE PNG download in a second ... that's 100 Mbits/sec. And try uploading some firmware - 700 MBYTE's takes just over a minute - again, the full wire-speed of 100 Mbits/second is doable bi-directionality.
Now download a video recording from the SD card (Record->Search->Select a clip->Download) which results in a speed 10X slower - it seems to be exactly TEN Mbps. ... with a 300 MBYTE .dav taking about FIVE minutes.
Yes, you can "fix" this by using the plug-in ... but there's no reason in 2025 you should have to do that. And as outlined above, the camera/network/computer is clearly capable of running at 100Mbps.
Seems like it would be worthwhile for Dahua to look at the browser integration code and get this fixed since while the video files eventually download, it's a bit annoying (and unnecessary) to wait that long.
BTW, I think someone did some work on the browser integration because on the 5442-S3, I would occasionally get "download blocked" if I did multiple snapshots ... and if I try to download multiple .dav files at the same time, that would not work. But it does work on the T54PRO-ZE ... so good progress! ;-)
FYI that the specs on the camera are 10/100 ... as both @TheOtherMike and @steve1225 point out, the interface is NOT Gbit.
2023_12_23 UPDATE: If you use Internet Explorer (with plug-in), you can download videos via the web interface at the full 100Mbps speed - note you can't go any faster because the NIC doesn't support GigE. Thanks @TheOtherMike for pointing that out on the data sheet (maybe for 2024, Dahua will go with 10/100/1000 interfaces) and thanks @wittaj for your (yet another) good suggestion to use Internet Explorer. This can be done by creating a desktop short-cut that has a Target of ""C:\Program Files (x86)\Internet Explorer\iexplore.exe" ienotdead -embedding"
Note that there is still an issue that in newer browsers (which mostly work without the plug-in), the download speed appears to be capped at 10Mbps.
Hopefully a future firmware release will fix this.
I recently got a T54IR-ZE-S3 ... two of them actually ... nice camera's.
It seems that if you use web interface to download videos directly from the camera (Record->Search->Select a clip->Download), the speed is capped at TEN Mbps.
The download popup shows KBytes/sec which quickly hits ~1,000 and stays there for the duration of the several minute download.
However, if use SmartPSS, the download is at least 10X faster - measured by stopwatch since it doesn't show rate. So clearly the cable/camera is capable of much faster download speeds ... so why is the web interface so slow?
I see the same behavior with Edge and Chrome. Since 1 MBYTE/second is (basically) 10Mbps, makes me wonder if some limitation is being applied?
Or maybe I'm just doing something obviously wrong ... but this is very straightforward.
On the camera, I'm running the latest 11/27/2023 Firmware from @EMPIRETECANDY.
SmartPSS is version V2.003.0000004.0.R.201021
Plenty powerful Windoze PC with GigE connection.
All internal LAN connected to same switch on same subnet.
P.S. Is there any way to determine (syslog bootup message?) what the NIC has negotiated for 10/100/1000 MBps?
Update: Answer appears to be NO from the camera itself, but you can, of course, look at the switch if it is managed and/or has an LED showing the link speed.
