We are part of a small test bed for a new fiber into the home internet service from Comcast / Xfinity. I am trying to setup a VPN server on my Asus RTAC68U router for blue iris but am getting an invalid IP address error during the DDNS step in this video. It gives me a note of "This router may be in the multiple-NAT environment and DDNS service cannot work in this environment." once the initial ip address error is closed.
The fiber modem, as comcast calls it, is acting as a router as well which is obviously what is leading to the double NAT. It does have a bridge mode but my TV service is run through the same device and enabling bridge mode knocks out all the TVs. I found a thread here with a similar problem and solution but disabling DHCP on the Asus did not help and switching the cable from my WAN port on the Asus to a LAN port cut off all internet access (except for google?).
The VPN primer for noobs thread is pretty clear that forwarding ports is not a good idea. Is this my only option at this point? Any other ideas to try?? I am at the absolute limit of my networking ability with this and not sure which direction to go...
