loveparabellum n3wb Jul 20, 2018 2 0 United States Jul 20, 2018 #1 Does BI have compatibility with any door sensors?
tangent IPCT Contributor May 12, 2016 4,641 3,996 Jul 20, 2018 #2 You can add i/o to blue iris and use wired sensors using a sealevel device or a number of other things. You can trigger blue iris using http commands from various home automation hubs that would work with zwave sensors. Reactions: fenderman, aristobrat and Q™
D danbutter Getting the hang of it May 28, 2017 139 47 Jul 21, 2018 #3 Yeah this could go a bunch of different ways. Why don't you explain what you are trying to accomplish. Then maybe more specific advice can be given.
Zorac Getting the hang of it Apr 17, 2015 213 26 Jul 29, 2018 #4 i use a raspberry pi to monitor a few door and gate sensors which then in turns triggers BI over my network. it could just as easily be done with an arduino though. there are a couple different ways you could trigger BI though.
