- Jan 19, 2017
- 5
- 1
Hi there,
1st post so go easy on me
Been researching & learning from this forum. Thank you to all of you that spend your time and effort helping us noobs!!!!!!
I have finished installing Ethernet all around my house for cameras and I am ready to start installing cameras. I will be using Blue Iris and already have a nice PC, i7 6700 and WD Purple 4tb drives. Will use Ubiquity Toughswitches for switch and POE functions.
I plan to use the HDW 5231R-Z turrets for most of my outside locations but I need to decide on camera and locations for doors and same for car/plate.
1st, which would be better, installing the HDW 5231R-Z turret just above the doors or a HFW4231S mini bullet installed at head height just off to the side of the door and recessed INTO the woodwork? My wife would prefer NOT to have an ugly camera thing sticking out in your face so that's why I thought of drilling into the wood and recess mounting the camera.
If I am barking up the wrong tree, please point my in the right direction.
2nd, I have a good location at the intersection of my driveway and the road to install a camera. It's a 4x4 mailbox post along with a 1/3 whiskey barrel type planter right up against it. I will run some sort of protected Ethernet cable out to this location so that gives me power and video. Would the HFW4231S mini bullet (easiest to hide) with a 6mm lens work for this? How about the IPC-HFW5231E-Z?
The distance for mounting location is less than 3' from the edge of the road. The distance from the road to my house is about 85' so it seems like the mailbox area is a better option if I can figure out how to hide / blend it in.
Thanks for any help or suggestions!!!!!
