I updated my Win 10 Pro server last week with the new Fall Creators Update and have had issues with Domoticz reporting multiple dead nodes on my two powered Plug in switches along with wrong states for my door triggers.
Anyone running Domoticz on a Windows 10 Pro server with the new Fall Creators Update without problems? Asking here since most of the forums on Domnoticz site seems to be people running on linux and I can't seem to find many messages pertaining to windows.
I tried reinstalling and updating Domoticz and that didn't help along with restarts/reboots/heal network etc. What is strange is a few times I'm able to reboot the system and was able to activate my light switch and the switch would work but then soon after it would report an error (would goto red state). I noticed door triggers weren't reporting correctly either.
Guessing this might be a driver/usb problem. I rolled back the FCU update and everything works like before no problems.
Windows 10 Pro (removed fall creators update)
Domoticz Version: 3.8153
Aeotec Z-Stick Gen 5. Z-Wave Plus USB
2xAeotec by Aeon Labs ZW097 Dry Contact Sensor
7xEcolink Battery Operated, Door/Window Sensor (DWZWAVE2-ECO)
2x Monoprice Z-Wave Plugin On/Off, NO LOGO Model 11995
One thing I wasn't aware of in the Fall Creators Update is that there is a new *feature* that if you restart windows it will reload Apps/Programs again on the restart of whatever you didn't fully close. Wondering if domoticz might be loading multiple times causing an issue (tried shutting down all processes and restarting etc).
I'll put my updates on hold, but hate knowing that my system might fail when the next update is forced on my system (have it on hold for 365 days).
