- May 6, 2018
- 11
- 8
I wanted to create a thread to type out what my current thoughts are on buying a dome camera over a turret camera or vice versa in order to help me make a decision. Please feel free to chip in on anything I have missed.
I am currently looking at two camera models DS-2CD2185FWD-I (dome) and DS-2CD2385FWD-I (turret) to purchase and hence I will post with these in mind.
IR
There are a few places online that I have seen that there have been advances in dome cameras specifically surrounding IR reflection. Whilst this is reassuring evidence says otherwise as seen in this video (it's quite evident too) however on the contrary this video has a perfectly clear image and you may even think the two videos are totally different cameras. On the flip side the turret camera from the same youtuber in the first link shows a quality image as shown here.
Is quality of installation a factor here and this is why there is a significant difference between the first two youtube links?
Physical concerns
The dome camera is slightly smaller in size vs the turret camera although the size can be easily forgotten about considering the dome camera is around 50% black in colour and therefore more conspicuous whereas the turret camera is much more inconspicuous considering there is much less black and more white.
The downside to the turret camera above is that it can be easily moved by an individual although you could argue that you could easily disable the dome camera with enough force as shown here (in my eyes he wasn't hitting it hard enough with the hammer). Alternatively if you really wanted to disable it you could easily remove the dome cover and yank at the internals should you be that way inclined. You can however question if the turret camera considering it is more inconspicuous due to its colour scheme would it be noticed less?
I have read that the plastic on the domes degrade after a while due to UV and need replaced so that is something to factor in as a possibility. You may also need to clean them more frequently due to their larger surface area.
Others
Changing the lens in a turret camera can be much harder considering you need to separate the housing and from what I have seen in the case of the turret camera listed above there is a chance to damage the cables joining both halves of the camera. In a dome camera all you have to do is lift off the dome.
Weighing up the differences
Am I correct in saying that physical interaction with the camera is a factor, whereby the camera can be physically accessed, it should be a done style camera otherwise it should be a turret camera?
I am still trying to figure out which camera I actually want to settle for hence this post however I'd appreciate any advice to allow me to make a decision.
IR
Physical concerns
Others
