Hey
So I have the 3MP Dome Hikvision anove my front door and the daytime image looks great.
The nighttime one looks odd however, sort of a flared effect?
I have another of exactly the same above the garage and this looks fine at night.
Front door
Garage which looks fine
Have tried to clean the dome inside and out to no avail and all the seals look fine.
The only thing I can think of is that it's mounted under an awning hangover thing above the door and in front of the lens is a white wooden beam which slopes downwards it's off the right side of the camera, probably 10cm away. You can see it in the right of the image.
Thanks
Front door
Thanks
