Hi Everyone! I'm a long time reader, first time poster and I've encountered an issue that I can't seem to resolve.
I'm running Blue Iris on an i5 4460 with 6gb RAM with 4 Hikvision DS-2CD2135F-IS (gray market) POE cameras.
https://www.amazon.ca/Hikvision-DS-...8077673&sr=8-1&keywords=hikvision+dome+camera
My problem is with one of the cameras located in my driveway. I readjusted the camera angle and ever since I've been having an issue with glare. The camera was originally aimed further downwards.
Thinking that I caused this by dirtying the glass when readjusting, I went back and made sure that everything was completely clean. To my surprise, the problem remained without the glass dome present. In fact, the above image is taken with the glass removed. I also tried re-adjusting the lens back to its original position however this glare effect remained.
I've tried just about every combination of settings on the camera's web GUI and the above image is about the best I can seem to achieve. It seems obvious that the issue is caused by the Infrared LEDs because if I manipulate the "Smart Supplement Light" manually and decrease the intensity, the glare fades. The problem with doing this, is that I must decrease the exposure time in order to compensate for the loss of light. This causes a terrible ghosting effect where I'm unable to obtain any discernible features from the video.
Furthermore, when my motion detection driveway lights are activated, the problem disappears entirely.
Camera settings for reference:
Brightness 50 | Contrast 50 | Saturation 50 | Sharpness 50
Iris Mode Manual | Exposure Time 1/25 | Gain 100
Smart Supplement Light On | Mode: Auto
Backlight: WDR On | WDR Level 10
White Balance AWB1
Digital Noise Reduction: Normal | Noise Reduction Level 100
The camera is located on the soffit in the upper right of the below image.
I'm truly at a loss as to how I went and screwed this up! My only other thought is that the camera is getting reflection from above. Whether it be from the soffit or the overhang beneath where the gutter is sitting. (Which you can see if you look closely)
I think that about covers it, let me know if there is any more information I can provide.
If anyone has ANY ideas as to what I can try I would greatly appreciate it!
Thanks!
Also, I'd like to add what a invaluable resource this forum has been time and time again while setting up my IP Cameras. Keep it up everyone! And thanks in advance for any replies!
Regards,
Jason
White Balance AWB1
Thanks!
Regards,
Jason
