- Jan 30, 2017
- 835
- 320
Tomorrow I am removing all of my Cat6a cable that's outside of the house and running straight into the house behind each camera. So all connections will be in the attic space. I'm still going to use the waterproof boots just to be on the safe side. No boxes or wires exposed.
1. I have the Dahua wall mount bracket. Is caulking the heck out of the connection and stuffing it in the mount sufficient waterproofing? This particular camera is not close enough to get the connection up in the attic area? I will be using the waterproof boot as well of course. And what about the 12v cable on these Starlights? For now I used some good caulk and plugged the hole to prevent moisture there.
2. No reason to waste the current cable? It's been outside for 2 weeks. I am just planning on snipping the ends and re-use it. Should be fine correct? I have a 1000' roll so I have plenty if you think I should.
3. Camera placement. Not that I want to put even more screw holes in my soffet but what is optimal position? Out towards the gutter or in close to the house?
I have 2 Bullet style Starlights coming next week hopefully. Courtesy of Andy of course. Thanks for your time and suggestions.
