Does the PFA200W Sun/Rain Shield fit the PFA130-E Junction Box?
Arjun
11,005
14,434
USA
I thought it would fit the 130e due to the same mounting holes as the 137
Right, I know it wasn't designed for the 130 but was hoping it might still work because of standard hole patterns. Does anyone have hands on experience? Alternatively, is there another option for a rain shield that doesn't require additional mounting holes?
Reactions: Arjun
The only idea I have is to create a template from the PFA137 and drill new holes on the PFA130e face-plate on the exact locations (as the PFA137) to see if that can work - you do sacrifice weatherproofing capabilities though due to the compromise to the gasket seal. However, you can always perhaps caulk sealant around that. For a plate that thin, not sure how feasible it would be to create a couple of threads though.
