There is so much misinformation out there and its pissing me off.
I want to consolidate several IP cams via a 16 port Netgear GS516TP ( https://www.amazon.com/NETGEAR-Rackmount-Lifetime-Protection-JGS516PE/dp/B00GG1ACX2 ).
Unfortunately my premier cam is a Dahua Starlite SD49225T-HN which need 13w/20w via POE+
(SD49225T-HN,SD49225T HN,SD49225THN )
some of the possible misinformation is that the POE+ will work on that Netgear as long as it stays under the 85watt budget.
so ultimately, will my Dahua Starlite PTZ cam work with that Netgear 16 Port POE Switch or not?
thanks in advance for any enlightenment.
