I got the above model NVR used. I did the password reset and then updated to the latest firmware. Everything seems to work as expected.
I have a bunch of cameras connected and working via ONVIF. The NVR will not integrate with the motion detection on a few camera models. This is probably due to incomplete ONVIF support in the cameras.
However, those cameras will HTTP post when an event is triggered. I have that part working. My goal was to use the 'soft' alarm inputs via the ISAPI interface to bridge the gap.
There's an app note here. I'm working with Postman. No matter what I've tried, I always get a 401 response.
I'm wondering if something has changed? I saw one post claim that ISAPI support had been removed from some Hikvision products.
Can someone using current NVR firmware post a simple verified Postman example?
Thanks!
--David
Thanks!
--David
