- Jun 20, 2015
- 129
- 8
[h=1]
2015 Multi-language Original Hikvision DS-2CD3345-I Full HD 4MP Dome IP Camera[/h]This is for the above listing on ebay. I think it is one of the new models, but I am not sure what the below means (especially since it is written in "chinglish". here is the page, if anyone needs more to go on:
http://www.ebay.com/itm/2015-Multi-...=222007&algo=SIC.MBE&ao=1&asc=20140122153519%
26meid%3Df5a05d4ecd2d4c53a1f821b36d741509%26pid%3D100022%26rk%3D2%26rkt%3D4%
26sd%3D221866567994
"Tips:Multi-language version, you need to use with plain English NVR,NVR version is not compatible with Brush,Packaging, brochures Chinese
H.265 encoding The camera needs NVR with the corresponding coding scheme used to achieve H.265 encoding before saving. NVR with non-H.265 coding using adaptive coding saved as H.264." ??????
26sd%3D221866567994
