H HBergeron n3wb Dec 15, 2023 1 0 Texas Dec 15, 2023 #1 I have installed Docker and the mrlt8/wyze-bridge container from GitHub on my Windows 10 box and can see my Wyze Cam Pan V3 at http://localhost:5000, but I can't figure out the video configuration entries to make it work with BI. Can anyone provide guidance on how to set it up? Thanks!
V vin ndarcur n3wb Jul 21, 2019 2 2 yorontp Feb 1, 2024 #2 HBergeron said: I have installed Docker and the mrlt8/wyze-bridge container from GitHub on my Windows 10 box and can see my Wyze Cam Pan V3 at http://localhost:5000, but I can't figure out the video configuration entries to make it work with BI. Can anyone provide guidance on how to set it up? Thanks! Click to expand... a little late for a reply but should help future users. for main stream profile can name it must match what the actual name is in wyze bridge Reactions: IrieMon69x
TheWaterbug Known around here Oct 20, 2017 1,075 2,046 Palos Verdes Jan 28, 2025 #3 Another small tip--if you run the Bridge on the same computer as Blue Iris, use the loopback address instead of its literal IP address: That way, if you transplant everything over to a new computer, it will still work.
