All of my cameras are fine, but these two always dip out and say no signal detected after a few minutes. I can't seem to figure out why. Any ideas?
Oh that explains it LOL.
Those are such new cameras and do things like splicing two images together into one and then with them not following normal ONVIF protocol, BI is probably interpreting it as no signal.
Does it actually No signal and you have no image or is it logging it as no signal but the image is still there? If it is the latter, just accept the bug.
In either case, probably need to send a request to BI support so they can look into it. it might be a simple coding fix hopefully.
haha yeah, the cables are def goodThe only time I've encountered that is with a bad cable on a Dahua camera and on a Reloink, even with a known good cable.
oh neat. thanks. Okay sounds good.Yeah, reach out to support. They will probably want access to the camera to see if it is something in the code they can fix for that particular camera.
A new camera status “bell” icon replaces the trigger icon once an alert is confirmed. This helps to emphasize the difference between the “triggered” and “alerted” states—not all triggers become alerts based on filters and AI analysis.
So it's actually both. The image will freeze on the screen for a period of time then it will say no signal randomly. They just sort of pop back and fourth every minute or so with a no signal.
Also, side note, what are the purple bells? I can't find their meaning anywhere in the BI manual with Ctrl F.
