Do you use AdGuard or Pi-Hole?
gwminor48
4,554
10,957
Texas
I've been considering using either one of these to cut down on ads. I notice Raspberry pi prices have gone through the roof due to chip shortage but I see other alternatives at a much lower price, some even able to use cases meant for Raspberry. How has your experience been with AdGuard, Raspberry pi, or hardware alternatives for this?
@gwminor48, I run PiHole on two RPi 4B for two and a half years with no problems. Very easy to update. Every now and then I have to go in and locate which URLs are being blocked to allow a few sites to operate correctly - those few sites can then be whitelisted.
I use gravity-sync to sync the blocklists between the two PiHole instances that I run - GitHub - vmstan/gravity-sync: The easy way to synchronize the DNS configuration of two Pi-hole 5.x instances.
on one of the PiHole I run OpenVPN and on the other I run WireGuard VPN.
