Bmr4life Young grasshopper Oct 14, 2018 41 20 Georgia Jul 25, 2019 #1 I have some Lechange NK168P083-IPC cameras that came in an NVR combo. Do these cameras only work through the NVR or can be they used with blue iris?
looney2ns IPCT Contributor Sep 25, 2016 16,556 24,622 Evansville, In. USA Jul 27, 2019 #2 Bmr4life said: I have some Lechange NK168P083-IPC cameras that came in an NVR combo. Do these cameras only work through the NVR or can be they used with blue iris? Click to expand... If they are indeed IP cameras, then they should work. One way to find out....
alastairstevenson Staff member Oct 28, 2014 16,307 7,077 Scotland Jul 27, 2019 #3 Bmr4life said: I have some Lechange NK168P083-IPC cameras that came in an NVR combo. Click to expand... Are they plugged in to PoE ports in the NVR itself? If so - they use that connection for power as well as data, so you'd need a PoE switch to connect and power the cameras when not connected to the NVR.
Bmr4life Young grasshopper Oct 14, 2018 41 20 Georgia Jul 27, 2019 #4 I went through the awkward process of using the dahua config tool to find the camera and reassign the IP address. It's a done deal. Reactions: catcamstar and alastairstevenson
