efkka23 n3wb Sep 19, 2022 12 6 Kauns Aug 16, 2023 #1 Hi. Is any way to rename tripwire? For example i have 4 tripwires and want rename like garden lake street and so on
P [email protected] Getting comfortable Dec 4, 2015 422 421 Aug 16, 2023 #2 When you create a tripwire, you have the opportunity to change the name from Rule 1,2,3,4 to any name you wish. Reactions: JDreaming, David L and looney2ns
efkka23 n3wb Sep 19, 2022 12 6 Kauns Aug 16, 2023 #3 [email protected] said: When you create a tripwire, you have the opportunity to change the name from Rule 1,2,3,4 to any name you wish. Click to expand... But dmss app always shows only tripwire not name as it set in rule config
bigredfish Known around here Sep 5, 2016 26,040 68,915 The Swamp Aug 16, 2023 #4 It might if you delete and add back the camera? Reactions: JDreaming and David L
efkka23 n3wb Sep 19, 2022 12 6 Kauns Aug 16, 2023 #5 bigredfish said: It might if you delete and add back the camera? Click to expand... From dmss app delete camera? bigredfish said: It might if you delete and add back the camera? Click to expand...
bigredfish Known around here Sep 5, 2016 26,040 68,915 The Swamp Aug 16, 2023 #6 Yes and add it back. It should pick up the new name. Reactions: JDreaming, David L and efkka23
