- Mar 8, 2015
- 2
- 0
Hi i'm vahid new here and new here
last week i was installing cams in a local school with hikvision 2132 3MPixel cameras.i used cat6 copper wires but i think cat5 wires could be the best choice to save bucks. because cams use 10/100 NIC and i think there is enough bandwidth with Cat5E .but i didn't take risk and wired them tonon POE Gbit switch.
to power the cameras i used 12V -30A power supply and i cut the brown and blue wires in the both end of cable and then i connected the Blue as positive and Brown as negative at power source side and connected the pair to camera with it's power jack/socket and patched orange/green with RJ45. every thing went well until night i noticed voltage drop when cameras turning their IR light ON.some of them are alright but 3 of them don't have enough illumination so i changed the voltage of power supply to 15 V but i scared to increase it more
here is my question :camera has 802.3af POE standard which means i can increase the power voltage up to 48V but i haven't used RJ45 jack only and i'm powering them with the other power socket.is this the same or the other power port is only for 12 V powering???
