I have a few HikVision DS-2DE2A404IW-DE3 cameras with different OEM branding so the models show up as: DS-2DE2A404IW-DE3 but also DT2A404 and HNP104-IR/4X. How do I update their firmware? I've tried downloading the latest 5.7.1 firmware but get a firmware mismatch error when trying to upgrade the cameras (including the DS-2DE2A404IW-DE3). All models are on 5.6.11, 5.6.12, or 5.6.14 so I don't know why they'd come up with mismatch. Does anyone have any suggestions? I know its not typically recommended to upgrade firmware unless their is an issue but I'm concerned about the recent backdoor vulnerabilities (they are on a no-Internet network) and two of my cameras are having severe issues that factory resetting has not helped.
I have a DS-2DE2A404IW-DE3 and a DT2A404 that have been constantly disconnecting since a network upgrade. I initially thought it was related to the network upgrade but I don't think so anymore because I swapped one of the broken cameras with a working one from one room to the other and the problems followed the camera. Connected to Blue Iris the cameras constantly disconnect. When they disconnect their webpages don't load. Its not a network issue because if you ping the cameras they never get signal loss. Even when they are working Blue Iris shows their connection at 50 to 200 kB/s while all others are at around 750 kB/s. Changing from 1080p30 to 720p30 didn't help, neither did factory resetting. The only thing I haven't tried is taking them apart to see if there is any physical factory reset switch or successfully getting them updated firmware.
