BI crashed last night while I was using the iOS app remotely. I was messing with the PTZ of one of the cameras when it stopped responding. I VNCed into my machine at home to discover the "close program" dialog from a crash:
Faulting application name: BlueIris.exe, version: 4.5.1.6, time stamp: 0x58bb05c6
Faulting module name: urlmon.dll, version: 11.0.9600.18538, time stamp: 0x58274f5c
Exception code: 0xc0000005
Fault offset: 0x000000000007e805
Faulting process id: 0xf14
Faulting application start time: 0x01d296e0761f88af
Faulting application path: C:\Program Files\Blue Iris 4\BlueIris.exe
Faulting module path: C:\Windows\system32\urlmon.dll
Report Id: 24010717-03a6-11e7-8599-e06995b7bcc4
Ken mentioned that if I run BI as a service that it will restart automatically if there is a crash.
I'm running Windows 7 (64), BI 4.0(latest) and have 12 cameras. CPU usage is around 16% despite the fact I have an old Sandy Bridge I5-2500s. CPU usage was much higher before I selected direct to disk and turned off all OSD processing.
Are there any disadvantages to running as a service? If there are, then I guess I could use another app to auto restart BI when it crashes. I'd also have to disable the windows crash reporting UI so that it doesn't get stuck on the "close program" box, but that's easy enough.
