I've experienced a few instances where the video for a particular camera has lagged significantly behind my other cameras.
When I've looked at a camera's settings while one of these events was happening the Status section of the General tab has shown a "Receive buffer bottleneck" warning.
Based on recommendations in another thread, on Sunday I bumped Receive buffer to 40 MB on all of my cameras.
This morning I observed another one of these events on a IPC-B54IR-Z4E-S3, again observed the Receive buffer bottleneck warning, and confirmed that the Receive buffer was set to 40 MB.
Just to see whether it might make a difference, I disabled the substream in the Video>Network IP>Stream profiles.
I then noticed that UI3 was showing a cropped image for that camera.
Here is what it looked like in UI3:
Here is what it looked like in the Blue Iris Console:
A restart of the camera had no effect.
A restart of Blue Iris had no effect.
For grins, and because the features of the latest Blue Iris version, 5.9.9.5, lists "UI3 update" I upgraded Blue Iris from 5.9.8.5 to 5.9.9.5.
The video for the camera remained cropped.
I then went into Video>Network IP>Stream profiles and enabled the sub stream again, and the UI3 window for the camera was back to a full view of the camera feed.
The behavior is reproduceable. Disable the sub stream and UI3 shows a cropped view of the camera. Enable it and the view in UI3 goes back to normal.
I also performed the same actions on an IPC-Color4k-X and saw the same behavior.
With the sub stream disabled, I've tried setting Anamorphic to both enabled and disabled with no noticeable effect.
Other than deleting the camera and adding it back I can't think of anything I haven't already tried.
@bp2008 have you ever seen this behavior?
