easy4ip login
Easy4Ip: http://<CAMERAIP>/cgi-bin/configManager.cgi?action=setConfig&T2UServer.Enable=false
乐橙商城-大华旗下乐橙官方网站
Lechange Pro: http://<CAMERAIP>/cgi-bin/configManager.cgi?action=setConfig&VSP_HS.Enable=false
(They call this one "WatchNet" in the config ^^)
If you don't use these features (I hope you don't) you can disable them to stop your camera from "calling home".
Some camera firmwares have the settings in the WebUI:
And this one is probably only on chinese firmware, which explains the stupid translation (It should be GB28181)....
And if you are asking yourself what this even is:
Easy4ip
Remote Access/Easy4IP Access Setup P2P Plus Signup - Dahua Wiki
Basically for people who can't set up firewall rules in their router or create a VPN your camera connects with dahuas servers and pipes the video through them to the device outside of your network which requested the video.
乐橙商城-大华旗下乐橙官方网站
Easy4ip
