Hi there!
I've installed N° 3 Dahua IPC-HFW3441E-S-S2 without NVR and these days I'm trying to configure them.
I have enabled the IVS function for detecting the human shape with related notifications on the smartphone.
When I'm at home I would like to disable this feature and I think with the API I can do it, I already read a lot on the forum but I couldn't disable the IVS rule (I use the API document version 2.89).
Could you help me find the correct string to enable and disable the IVS rule?
Thanks in advance.
Thanks in advance.
