Direct-to-wire seems broken under latest releases
erkme73
BIT Beta Team
Nov 9, 2014
1,621
1,538
I operate with all of my cameras on a profile which uses direct-to-wire so that the raw stream from the camera is pushed through to the client without any manipulation by the BI server. Thus, no overlays, image changes, etc. That's fine, as it results in a sharper, more fluid video compared to any of the reencoded profiles.
However on the latest update(s) the direct-to-wire functionality seems to have been borked. I get only a spinning wheel. Recorded clips and re-encoded profiles work fine. I checked on the BI console and found that the direct-to-wire was UNchecked (which I didn't do). I re-enabled it hoping the function would restor - it did not.
Has anyone else been able to use the D2W function on the latest releases?
