I'm using D2D .bvr format and the files that are being produced will play in MPC , but you cannot control the video. There is no pause, no FF, RW nothing... Is this a known issue or am I just doing it wrong?
Format : AVC
Format/Info : Advanced Video Codec
File size : 37.4 MiB
Video
Format : AVC
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=6
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Color range : Limited
