I recently bought a chinese Wifi PT camera branded as CareCam (Model No. WIFI-TF-PTX (10X)). There is a dedicated app for the camera known as carecampro on playstore which works fine. Camera can also be connected to PC via WIFI or rj45 cable using a wifi router . I want to connect this camera to a PC (windows 10 ) without the middle man i.e router. When I connect the camera directly to the PC via ethernet cable my PC got assigned a Autoconfiguration IPv4 Address :169.254.86.33 and no IPv4 Deafault Gateway and manually filling IP address and gate way to 192.168.66.101/1 is not helping either on the otherhand in wireless connection I got assigned Autoconfiguration IPv4 Address : 192.168.66.101 and IPv4 Deafault Gateway : 192.168.66.1 . Any help in this regards is appriciated.
Additional Information if it helps:-
Camera manufacturer does not provide IP address, no port number and no Admin password anywhere on the box or manual.
I got IP address (192.168.66.1) and port no. (6688) from NoRoot Firewall (Android) when the CareCam Pro app tries to connect to the camera and searched internet for Admin password (admin1234546).
I scanned open ports of camera (192.168.66.1) from the app named as RoboShadow-Network Scanner (Android) and found 8 open ports all are TCP ports no HTTP port was found .
Cannot open "" in google chrome (mobile or PC) it says refused to connect but working in Onvier Android App or IP camera viewer4 (PC)
Rtsp stream " rtsp:/192.168.66.1:8554/profile0" is not needed anywhere and got auto detected by apps.
The carecampro app was trying to connect to a Thailand server (43.133.107.118) but I blocked it in firewall.
