Hey all!
New user here....
I have a Annke poe cctv system. All working fine until the nvr crapped out and does not power up. The Annke i21g poe cams still work.
Thinking of purchasing hikvision nvr. Apparently I will need to change the ip addresses on the cameras before the nvr will detect them. So, my problem is gaining direct access to the cams to modify the ip addresses.
The i21g cameras are SPOE 12v with only the rj45 poe port which connects to nvr for power andd data.
How do i power on these cams without the nvr?
contacted annke and they said these cams can only be powered by the nvr.
New user here....
