No replies, I guess I am on my own.Just noticed my plate search program has an error, not sure what went wrong. Did it change, or did something BI do that made it crash?
Thanks.
Gary
I don’t think so. I have a backup computer also that seems to work fine. Both running the same version. I get an error that says. C Error, Buffer Overflow caught. Possible malformed input file. I guess I will wait for the month to turn over and see if the new month works okay. Unless you know what is going on. The program is called Plate Search. Is there another one out there that is better? Everything has been running good, so I don’t get out on this site very often.Which program are you using - there are several?
Did it correspond to an update?
Posting it in the program thread of the one you are using would likely have got a response.
I’ve never heard of this one before. Do you have a link that you can share?The program is called Plate Search.
No link, I got if from somebody on here. This computer is a Mac, so it’s not on my physical computer. I could probably move it over and attach it. Okay I did it I think. Didn’t find anybody’s name on it. Works good on my other unit still.I’ve never heard of this one before. Do you have a link that you can share?
I did a search of the entire site for "Plate Search" and came up empty, so I'm not sure which program you are referring to.No link, I got if from somebody on here.
We're just trying to understand what application it is so that maybe we can help. I'd ask you take a screen shot and post it here, but for some reason the site isn't allowing users to add images to their posts right now.NOt sure I understood a question
So, I will have to continue this over on my Windows computer and figure how to install it. I assume it installs to the CodeProject system? Can my ALPR server be on my Windows machine?We're just trying to understand what application it is so that maybe we can help. I'd ask you take a screen shot and post it here, but for some reason the site isn't allowing users to add images to their posts right now.
Regardless, this is probably one of the best free license plate apps I have found so far:
GitHub - algertc/ALPR-Database: Fully-Featured Automated License Plate Recognition Database Platform for Blue Iris + CodeProject AI Server
Fully-Featured Automated License Plate Recognition Database Platform for Blue Iris + CodeProject AI Server - algertc/ALPR-Databasegithub.com
It runs in a docker container and can be installed anywhere as long as the computer is always on.I assume it installs to the CodeProject system?
YesCan my ALPR server be on my Windows machine?
