DH_IPC-HX2X3X-Rhea_MultiLang_NP_Stream2_V2.800.0000004.0.R.190122
EMPIRETECANDY
IPCT Vendor
Nov 8, 2016
9,110
26,555
HONGKONG
Attached file is the supporting models, can update on model with DH or without DH.
IPC-HFW1831C-PIR,i already send @fenderman to make a testing, it's good. But still have some bugs.
IPC-HDW2231R-ZS
IPC-HDBW2231R-ZS
DH-IPC-HFW2231T-ZS
Bug fixture
Modify the SNMP public security vulnerability. The encryption mode is changed from "CBC-DES" to "CFB-AES".
2, OSD reconstruction (geographic reconfiguration and domestic related customization requirements processing, font size, color adjustable; channel name and geographic line number can be expanded, add custom OSD function, etc.)
3, the device supports RTMP protocol to achieve live video
4, double national standard function
5, network security 2.0 (including GDPR2.0 related requirements, there are 25 integrated)
6, intelligent refactoring, application code internal logic optimization
7. The device supports smart memory cards, supports Dahua SD card, and realizes SD card health monitoring and data encryption.
8, broken network resume transmission strategy adjustment and current use problem repair
9, equipment internationalization needs, equipment initialization strategy adjustment
10, the mail header is customized, look at the message header to easily locate the device that generates the alarm
11.Add H264 main profile to the S3LM platform coding mode.
2231 with chrome? IE doesn't ask me for plugin but with chrome it just shows spinning circle in live video view.
