DH-IPC-HFW4431R-Z Setup
Keech
Oct 30, 2017
2
1
Hi there
Have recently purchased a couple of the following cameras DH-IPC-HFW4431R-Z.
The one issue I have is getting them to reliably work in IP Camera Viewer, they seem to connect and then disconnect the exact model number isn’t there.
In addition on surveillance station in the Synology NAS what model should be selected?
Thanks in advance.
Hi there
Thanks in advance.
Welcome Keech,
I noticed that you've made your first post here so I wanted to welcome you.
I don't have an answer for you w/your question, hopefully we'll see a reply here soon.
It's easy to get swamped with information here, so I wanted to share some notes with you
Please check out @giomania 's notes:
Dahua Starlight Varifocal Turret (IPC-HDW5231R-Z)
I have also made notes which are a summary of a lot of the reading I've been doing here,:
Looking for some advice and direction!
Have fun joining us here.
Thanks for that, have done a fair whack of reading the past few weeks, previously used Foscam cameras so know a little but you can never have enough knowledge so will check the links out for sure.
