Greetings from a retired Englishman living in Thailand. I'm not a bot
Good site this, Thanks
I have the opportunity to buy two Dahua DH-IPC-HFW2449M-S-PRO 1/1.8" (doesn't say focal length) and one DH-IPC-HDW2449T-S-PRO 1/1.8" (2.8 mm) from an authorised Dahua retailer with full Dahua Thailand 3 year warranty for USD 248 including freight. I find that to be a very good price in Thailand. Normal price is USD 350.
Are they any good? For USD89 each? Old model? What's the catch?
Thank you
Michael
Specifications from the Dahua Thailand website
DH-IPC-HFW2449M-S-PRO (going to use these outdoors)
Now, the model I find on the Dahua Thailand website is IPC-HFW2449M-S-B-PRO Not sure what the B stands for but the ones I will buy doesn't have it
4MP WizColor Fixed-focal Bullet WizSense Network Camera
4-MP 1/1.8" CMOS image sensor, low luminance, and high definition image.
Outputs max. 4 MP (2688 × 1520) @20 fps, and supports 2560×1440 (2560 × 1440) @25/30 fps.
H.265 codec, high compression rate, ultra-low bit rate.
Built-in warm light, and the max. illumination distance is 50 m.
ROI, SMART H.264+/H.265+, flexible coding, applicable to various bandwidth and storage environments.
Rotation mode, WDR, 3D NR, HLC, BLC, digital watermarking, applicable to various monitoring scenes.
Intelligent monitoring: Intrusion, tripwire (the two functions support the classification and accurate detection of vehicle and human)
Abnormality detection: Motion detection, video tampering, audio detection, no SD card, SD card full, SD card error, network disconnection,
IP conflict, illegal access, and voltage detection.
Supports max. 256 G Micro SD card; built in Mic.
12 VDC/PoE power supply, easy for installation.
IP67 protection.
SMD Plus
IPC-HDW2449T-S-PRO (going to use this one indoors)
4MP WizColor Fixed-focal Eyeball WizSense Network Camera
Built-in warm light, and the max. illumination distance is 30 m.
Abnormality detection: Motion detection, video tampering, audio detection, no SD card, SD card full, SD card error, network disconnection, IP conflict, illegal access, and voltage detection.
IP67 protection.
SMD Plus
Thank you
Michael
IP67 protection.
SMD Plus
Image Sensor | 1/1.8" CMOS | ||||
Max. Resolution | 2688 (H) × 1520 (V) | ||||
ROM | 128 MB | ||||
RAM | 256 MB | ||||
Scanning System | Progressive | ||||
Electronic Shutter Speed | Auto/Manual 1/3 s–1/100,000 s | ||||
Min. Illumination | 0.0005 [email protected] | ||||
S/N Ratio | >56 dB | ||||
Illumination Distance | Up to 50 m (164.04 ft) (Warm light) | ||||
Illuminator On/Off Control | Auto;Manual | ||||
Illuminator Number | 4 (Warm light) | ||||
Lens Type | Fixed-focal | ||||
Lens Mount | M16 | ||||
Focal Length | 3.6 mm; 6 mm | ||||
Max. Aperture | F1.0 | ||||
Field of View | 3.6 mm: H: 94°; V: 50°; D: 113° 6 mm: H: 58°; V: 31°; D: 67° | ||||
Iris Control | Fixed | ||||
Close Focus Distance | 3.6 mm: 2.6 m (8.53 ft) 6 mm: 5.4 m (17.72 ft) | ||||
DORI Distance | Lens | Detect | Observe | Recognize | Identify |
3.6 mm | 70.3 m (230.64 ft) | 28.1 m (92.19 ft) | 14.1 m (46.26 ft) | 7.0 m (22.97 ft) | |
6 mm | 116.6 m ( 382.55 ft) | 46.6 m ( 152.89 ft) | 23.3 m ( 76.44 ft) | 11.7 m ( 38.39 ft) | |
DORI (Detect, Observe, Recognize, Identify) is a standard system (EN-62676-4) for defining the ability of a person viewing the video to distinguish persons or objects within a covered area. The numbers in this table do not reflect intelligent function distances. For intelligent function distances, refer to installation and commissioning manual/project design tool. | |||||
IVS (Perimeter Protection) | Intrusion, tripwire (the two functions support the classification and accurate detection of vehicle and human) | ||||
SMD | SMD Plus | ||||
Smart Search | Work together with Smart NVR to perform refine intelligent search, event extraction and merging to event videos | ||||
Video Compression | H.265; H.264; H.264H; H.264B; MJPEG (Only supported by the sub stream) | ||||
Smart Codec | Smart H.265+; Smart H.264+ | ||||
Video Frame Rate | Main stream: 2688 × 1520@(1–20 fps)/2560 × 1440@(1–25/30 fps) sub stream: 704 × 576@(1–25 fps)/704 × 480@(1–30 fps) *The values above are the max. frame rates of each stream; for multiple streams, the values will be subjected to the total encoding capacity. | ||||
Stream Capability | 2 streams | ||||
Resolution | 4M (2688 × 1520/2560 × 1440); 3M (2304 × 1296); 1080p (1920 × 1080); 1.3M (1280 × 960); 720p (1280 × 720); D1 (704 × 576/704 × 480); VGA (640 × 480); CIF (352 × 288/352 × 240) | ||||
Bit Rate Control | VBR;CBR | ||||
Video Bit Rate | H.264: 32 kbps–6144 kbps; H.265: 12 kbps–6144 kbps | ||||
Day/Night | Color/B/W | ||||
BLC | Yes | ||||
HLC | Yes | ||||
WDR | 120 dB | ||||
White Balance | Auto; natural; street lamp; outdoor; manual; regional custom | ||||
Gain Control | Auto/Manual | ||||
Noise Reduction | 3D NR | ||||
Motion Detection | OFF/ON (4 areas, rectangular) | ||||
Region of Interest (RoI) | Yes (4 areas) | ||||
Smart Illumination | Yes | ||||
Image Rotation | 0°/90°/180°/270° (Support 90°/270° with 2688 × 1520 resolution and lower) | ||||
Mirror | Yes | ||||
Privacy Masking | 4 areas | ||||
LDC | Yes | ||||
Built-in MIC | Yes, built-in Mic | ||||
Audio Compression | G.711a; G.711Mu; PCM; G.726 | ||||
Alarm Event | No SD card; SD card full; SD card error; network disconnection; IP conflict; illegal access; motion detection; video tampering; tripwire; intrusion; audio detection; voltage detection; SMD; security exception | ||||
Network Port | RJ-45 (10/100 Base-T) | ||||
SDK and API | Yes | ||||
Network Protocol | IPv4; IPv6; HTTP; TCP; UDP; ARP; RTP; RTSP; RTCP; RTMP; SMTP; FTP; SFTP; DHCP; DNS; DDNS; QoS; UPnP; NTP; Multicast; ICMP; IGMP; NFS; PPPoE; P2P; Bonjour; Auto Registeration | ||||
Interoperability | ONVIF (Profile S & Profile G & Profile T); CGI | ||||
User/Host | 20 (Total bandwidth: 48 M) | ||||
Storage | FTP; SFTP; Micro SD card (support max. 256 GB); NAS | ||||
Browser | IE; Chrome; Firefox | ||||
Management Software | Smart PSS Lite; DSS; DMSS | ||||
Mobile Client | iOS;Android | ||||
Cyber Security | Video encryption;Firmware encryption;Configuration encryption;Digest;WSSE;Account lockout;Security logs;IP/MAC filtering;Generation and importing of X.509 certification;syslog;HTTPS;802.1x;Trusted boot;Trusted execution;Trusted upgrade;Session security;Security warning | ||||
Certifications | CE-LVD: EN62368-1; CE-EMC: Electromagnetic Compatibility Directive 2014/30/EU | ||||
Power Supply | 12 VDC; PoE | ||||
Power Consumption | Basic: 2.0 W (12 VDC); 2.5 W (PoE); Max.: 5.7 W (12 VDC); 6.8 W (PoE) (H.265+ intelligence on + WDR + illuminator intensity) | ||||
Operating Temperature | –40 °C to +60 °C (–40 °F to +140 °F) | ||||
Operating Humidity | ≤95% (RH), non-condensing | ||||
Storage Temperature | –40 °C to +60 °C (–40 °F to +140 °F) | ||||
Storage Humidity | ≤95% (RH), non-condensing | ||||
Protection | IP67 | ||||
Casing Material | Metal + plastic | ||||
Product Dimensions | 201.0 mm × 103.8 mm × 97.8 mm (7.91" × 4.09" × 3.85") (L × W × H) | ||||
Net Weight | 0.68 kg (1.50 lb) | ||||
Gross Weight | 1.27 kg (2.80 lb) |
IP67 protection.
SMD Plus
ROM | 128 MB | ||||
RAM | 256 MB | ||||
Illumination Distance | Up to 30 m (98.43 ft) (Warm light) | ||||
Illuminator Number | 2 (Warm light) | ||||
Angle Adjustment | Pan: 0°–360° Tilt: 0°–78° Rotation: 0°–360° | ||||
Focal Length | 2.8 mm; 3.6 mm | ||||
Field of View | 2.8 mm: H: 112°; V: 60°; D: 134° 3.6 mm: H: 94°; V: 50°; D: 113° | ||||
Close Focus Distance | 2.8 mm: 1.7 m (5.58 ft) 3.6 mm: 2.6 m (8.53 ft) | ||||
2.8 mm | 57.9 m ( 189.96 ft) | 23.2 m ( 76.12 ft) | 11.6 m ( 38.06 ft) | 5.8 m ( 19.03 ft) | |
3.6 mm | 70.3 m ( 230.64 ft) | 28.1 m ( 92.19 ft) | 14.1 m ( 46.26 ft) | 7.0 m ( 22.97 ft) | |
IVS (Perimeter Protection) | Intrusion, tripwire (the two functions support the classification and accurate detection of vehicle and human); | ||||
BLC | Yes | ||||
HLC | Yes | ||||
WDR | 120 dB | ||||
Mirror | Yes | ||||
LDC | Yes | ||||
Certifications | CE-LVD: EN62368-1; CE-EMC: Electromagnetic Compatibility Directive 2014/30/EU; | ||||
Power Consumption | Basic: 2.0 W (12 VDC); 2.5 W (PoE); Max.: 5.3 W (12 VDC); 6.4 W (PoE) (H.265+ intelligence on + WDR + illuminator intensity) | ||||
Casing Material | Inner core: Metal; Cover: Plastic | ||||
Product Dimensions | 109.5 mm × Φ109.9 mm (4.31" × Φ4.33") | ||||
Net Weight | 0.42 kg (0.93 lb) | ||||
Gross Weight | 0.59 kg (1.30 lb) |
